ploddo
Message 1 of 12
line stats
Anyone any ideas regarding the upstream attenuation change and the connection speed drop please?
11-09-16DSL Link DownstreamUpstream
 Connection Speed52.51 Mbps8.06 Mbps
 Line Attenuation22.30 dB23.70 dB
 Noise Margin6.00 dB 6.30 dB
 DSL LinkDownstreamUpstream
16-09-16Connection Speed49.00 Mbps8.07 Mbps
 Line Attenuation22.50 dB24.10 dB
 Noise Margin7.30 dB6.90 dB
29-09-16DSL LinkDownstreamUpstream
 Connection Speed44.00 Mbps8.21 Mbps
 Line Attenuation22.20 dB34.90 dB
 Noise Margin9.90 dB5.90 dB
10-10-16DSL LinkDownstreamUpstream
 Connection Speed44.00 Mbps7.98 Mbps
 Line Attenuation22.50 dB34.70 dB
 Noise Margin9.50 dB6.10 dB
11-10-16DSL LinkDownstreamUpstream
rebootedConnection Speed44.00 Mbps8.15 Mbps
 Line Attenuation22.20 dB34.70 dB
 Noise Margin9.70 dB6.00 dB
11 REPLIES 11
john46
Message 2 of 12
Re: line stats
Have you tried the quiet line test dial 17070 option 2 you should hear no noise if you can hear noise then it needs reporting to BT faults on 151 with no mention of broadband in the call
the drop in connection speed is due to your noise margin increasing
Webby
Message 3 of 12
Re: line stats
Banded profile on the downstream. Not sure why the upstream has changed.
What are the results for your line from the wholesale DSL checkee?
ploddo
Message 4 of 12
Re: line stats
BT BROADBAND AVAILABILITY CHECKER
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High Low High Low
VDSL Range A (Clean) 58.5 44.6 15.2 10 -- Available -- --
VDSL Range B (Impacted) 46.7 27.8 11.2 5.6 --
ploddo
Message 5 of 12
Re: line stats
Yes does sound a bit fuzzy. Maybe it needs reporting. Thanks
ploddo
Message 6 of 12
Re: line stats
An IP reset was requested on Tuesday and a follow up phone call should have happened on Thursday. Needless to say neither have been forthcoming.
DSL Link Downstream Upstream
Connection Speed 44.00 Mbps 8.21 Mbps
Line Attenuation 22.10 dB 34.60 dB
Noise Margin 9.30 dB 6.00 dB
licquorice
Message 7 of 12
Re: line stats
Do you mean a DLM reset? If so who made the request to whom? Have you had an engineer visit, you cannot get a DLM reset unless an engineer fixes a fault.
Webby
Message 8 of 12
Re: line stats
DLM cannot be reset remotely.
You'v been fobbed off.
ploddo
Message 9 of 12
Re: line stats
BT online chat said they would request an IP reset which would take 24 hours....
licquorice
Message 10 of 12
Re: line stats
Not a chance if they meant DLM reset. IP reset is meaningless.
