anyone know what these are
21:48:56, 13 Sep. | (864052.520000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,4 VALUE CHANGE' |
21:48:55, 13 Sep. | (864051.130000) CWMP: Initializing transaction for event code M Download |
21:48:55, 13 Sep. | (864051.130000) transfer completed successfully |
21:48:52, 13 Sep. | (864048.200000) CWMP: session completed successfully |
21:48:52, 13 Sep. | (864047.980000) CWMP: Download file, FileType=4, FileName=4a-5app-bundle-v3-package.tar.gz.aes.rsa.signed, Username=, CommandKey=1736293426 |
Probably a firmware upgrade, or a change in the configuration file initiated by BT. This can also happen if you have recently opted in or out of BT Wifi.
There are also other changes that BT sometimes make to the internal applications running on the home hub.
it cant be firmware update as was already on the latest unless they are releasing a new one for hub 4?
what i am noticing is web pages are loading quicker and computer generally feels faster?
@shamus1 wrote:anyone know what these are
21:48:56, 13 Sep. (864052.520000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,4 VALUE CHANGE' 21:48:55, 13 Sep. (864051.130000) CWMP: Initializing transaction for event code M Download 21:48:55, 13 Sep. (864051.130000) transfer completed successfully 21:48:52, 13 Sep. (864048.200000) CWMP: session completed successfully 21:48:52, 13 Sep. (864047.980000) CWMP: Download file, FileType=4, FileName=4a-5app-bundle-v3-package.tar.gz.aes.rsa.signed, Username=, CommandKey=1736293426
Current evidence suggests that this is connected to the Home Hub 4 A now broadcasting BTWiFi-X SSID.
Can you confirm ?
my bt fon is deactivated?
for a long time i had been getting this in my logs
(765310.500000) CWMP: Set Parameter by TR069 failure 9005: Invalid parameter name
but since the log entries
i am now getting
21:48:58, 14 Sep. | (950453.180000) CWMP: Set Parameter by TR069 Success |
21:48:56, 14 Sep. | (950450.560000) CWMP: Set Parameter by TR069 Success |
@shamus1 wrote:for a long time i had been getting this in my logs
21:48:56, 13 Sep. (864052.520000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,4 VALUE CHANGE' 21:48:55, 13 Sep. (864051.130000) CWMP: Initializing transaction for event code M Download 21:48:55, 13 Sep. (864051.130000) transfer completed successfully 21:48:52, 13 Sep. (864048.200000) CWMP: session completed successfully 21:48:52, 13 Sep. (864047.980000) CWMP: Download file, FileType=4, FileName=4a-5app-bundle-v3-package.tar.gz.aes.rsa.signed, Username=, CommandKey=1736293426 i am now getting
21:48:58, 14 Sep. (950453.180000) CWMP: Set Parameter by TR069 Success 21:48:56, 14 Sep. (950450.560000) CWMP: Set Parameter by TR069 Success
This may not be significant as I have had both the success and failure messages after the download of the file.
