Expert
Message 1 of 10
log entries
anyone know what these are
21:48:56, 13 Sep.(864052.520000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,4 VALUE CHANGE'
21:48:55, 13 Sep.(864051.130000) CWMP: Initializing transaction for event code M Download
21:48:55, 13 Sep.(864051.130000) transfer completed successfully
21:48:52, 13 Sep.(864048.200000) CWMP: session completed successfully
21:48:52, 13 Sep.(864047.980000) CWMP: Download file, FileType=4, FileName=4a-​5app-​bundle-​v3-​package.tar.gz.aes.rsa.signed, Username=, CommandKey=1736293426
9 REPLIES 9
Message 2 of 10
Re: log entries
Probably a firmware upgrade, or a change in the configuration file initiated by BT. This can also happen if you have recently opted in or out of BT Wifi.
There are also other changes that BT sometimes make to the internal applications running on the home hub.
Expert
Message 3 of 10
Re: log entries
it cant be firmware update as was already on the latest unless they are releasing a new one for hub 4?
Expert
Message 4 of 10
Re: log entries
what i am noticing is web pages are loading quicker and computer generally feels faster?
Message 5 of 10
Re: log entries
not every change shows as a firmware upgrade but as Keith has posted that is a config file change
Recognised Expert
Message 6 of 10
Re: log entries
Current evidence suggests that this is connected to the Home Hub 4 A now broadcasting BTWiFi-X SSID.
Can you confirm ?
Expert
Message 7 of 10
Re: log entries
my bt fon is deactivated?
Message 8 of 10
Re: log entries
have you deactivated it at some time
Expert
Message 9 of 10
Re: log entries
for a long time i had been getting this in my logs
(765310.500000) CWMP: Set Parameter by TR069 failure 9005: Invalid parameter name
but since the log entries
i am now getting
21:48:58, 14 Sep.(950453.180000) CWMP: Set Parameter by TR069 Success
21:48:56, 14 Sep.(950450.560000) CWMP: Set Parameter by TR069 Success
Recognised Expert
Message 10 of 10
Re: log entries
i am now getting
This may not be significant as I have had both the success and failure messages after the download of the file.
