DAFTLAD
Newbie
Message 1 of 10
loss of broadband
can you help me broadband has worked fine untill i got a cordless phone this weekend as soon as i connected the new phone i lost my internet any ideas i have tried another cordless phone it does the same. a normal phone works ok and i still have broadband working has any one come across this one be for
9 REPLIES 9
Message 2 of 10
Re: loss of broadband
have you tried a new filter?  is the phone base station away from the the router in case of interference?
DAFTLAD
Newbie
Message 3 of 10
yes tried a new filter still no luck
Bert93
Message 4 of 10
try and buy one of the faceplate filters, visit the link below this,
http://www.homestead.co.uk/productcategorydetail.aspx?CategoryID=55291
___________________________________________________
Kind Regards, Bert
Message 5 of 10
Hi bert93
yours with filtered faceplate still going ok?
Bert93
Message 6 of 10
working brilliant to be honest mate 😄 these are good things bt should supply these on installation instead of them stupid micro filters! 😛 thanks 😄
Kind Regards, Bert
Message 7 of 10
they do eventually if you are having problems often the engineer will fit one - cuppa and choccy biscuit helpsSmiley Wink
Bert93
Message 8 of 10
i honestly cant believe changing the micro-filter to the faceplate filter solved my problems, little things make a big difference... wouldn't have managed it without you and john 😉 LEGENDS!
Kind Regards, Bert
Message 9 of 10
Thanks for the comment Bert
Bert93
Message 10 of 10
always welcome john, i praise you guys!! 😉
Kind Regards, Bert
