Callis
Message 1 of 15
low (0.1mb) upload speed
Hi there,
I hope someone can help. I can get a max upload speed of 8mb and upload can be anything from 0.1mb to 0.4mb. Literally we can barely use the Internet.
Can anyone help?
Thanks,
Callis.
14 REPLIES 14
john46
Message 2 of 15
Re: low (0.1mb) upload speed
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Callis
Message 3 of 15
Line state: Connectedppp3_0 Connection time: 0 days, 04:12:16 Downstream: 8.259 Mbps Upstream: 535 Kbps
Callis
Message 4 of 15
BT BROADBAND AVAILABILITY CHECKER Telephone Number 01707****** on Exchange POTTERS BAR is served by Cabinet 1 Featured Products Downstream Line Rate(Mbps) Upstream Line Rate(Mbps) Downstream Range(Mbps) Availability Date High Low High Low FTTC Range A (Clean) 10.5 5.7 1.2 0.8 -- Available FTTC Range B (Impacted) 7.4 2.4 1.2 0.5 -- Available WBC ADSL 2+ Up to 1.5 -- 0.5 to 2.5 Available ADSL Max Up to 1 -- 0.75 to 2.5 Available WBC Fixed Rate 0.5 -- -- Available Fixed Rate 0.5 -- -- Available Other Offerings Fibre Multicast -- -- -- Available Copper Multicast -- -- -- Available For all ADSL and WBC Fibre to the Cabinet (FTTC or WBC SOGEA) services, the stable line rate will be determined during the first 10 days of service usage. This line has jumpers in place. For FTTC Ranges A and B, the term "Clean" relates to a line which is free from any wiring issues (e.g. Bridge Taps) and/or Copper line conditions, and the term "Impacted" relates to a line which may have wiring issues (e.g. Bridge Taps) and/or Copper line conditions. Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises. The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 31-Oct-2013; the Formal Retirement date for IPstream is from 30-Jun-2014.
Callis
Message 5 of 15
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 7.56 Mbps
0 Mbps8.18 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 7.56 Mbps
 For your connection, the acceptable range of speedsis 5.73 Mbps-8.18 Mbps .
 Additional Information:
 IP Profile for your line is - 8.18 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.1 Mbps
0 Mbps2 Mbps
Callis
Message 6 of 15
Is any further information needed?
imjolly
Message 7 of 15
If you have a hh4/5 can you go to hub manager then troubleshooting then helpdesk and post the stats please. Your connection speed at 8mb is significantly better than the checker estimate so I wonder what you would get on infinity - more than the estimate?   Maybe but estimate for fibre is based on distance from cabinet nd not exchange like adsl2
Callis
Message 8 of 15
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Hub. This page contains all of the information they are likely to request.
1. Product name:BT Business Hub
2. Serial number:+076399+NQ42923819
3. Firmware version:Software version 4.7.5.1.83.8.200 (Type A) Last updated 04/10/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 06:27:35
6. Data rate:535 / 8457
7. Maximum data rate:543 / 9753
8. Noise margin:6.1 / 5.1
9. Line attenuation:12.5 / 10.4
10. Signal attenuation:12.6 / 31.5
11. Data sent/received:733.5 MB / 917.6 MB
12. Broadband username:B300469@hg7.btclick.com
13. BT Wi-fi:Yes
14. Static IP:Disabled
15. 2.4 GHz Wireless network/SSID:Peplins105
16. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
17. 2.4 GHz Wireless security:WPA2
18. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
19. 5 GHz Wireless network/SSID:Peplins105
20. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
21. 5 GHz Wireless security:WPA2
22. 5 GHz Wireless channel:Automatic (Smart Wireless)
23. Firewall:Default
24. MAC Address:c8:91:f9:32:0d:66
25. Modulation:G.993.2 Annex B
26. Software variant:AA
27. Boot loader:1.0.0
imjolly
Message 9 of 15
That explains why your speed is higher than expected for adsl - because you are on broadband with fibre
Callis
Message 10 of 15
Ok - thanks. So how can i imporve my upload speed?
