Florence11
Message 1 of 6
low Infinity speed and frequent disconnections - intermittent noise on line
Hi,
I am hoping that someone will be able to help me resolve the problem with my Infinity connection.  The download speed seems to stabilise at around 20 mbps but has dropped to as low as 7 in the past. The connection will be fine for several days, followed by 2/3 days of the broadband constantly dropping out, often every 5 – 10 minutes over several hours. This seems to be after heavy rain or in damp weather conditions.
I raised a fault in October after a diagnostic test showed that something was wrong.  An engineer visited and confirmed that the internal wiring was all okay.  I explained that the fault and the noise on the line is intermittent, but the quality was fine during the quiet line test. He replaced the hub 3 with a hub 5 and advised that the line and broadband tested okay, except for the low speed of 20 mbps. He went off to check the cabinet and exchange equipment; following this there was a huge improvement in the clarity of landline calls.
After a few weeks the download speed (on Infinity 2) reached 28mbps. As we were out of contract I called BT to renew for a further year; it was suggested that we drop down to Infinity 1 due to the speed issue.
Over the last few weeks the problem has returned, there is a buzzing on the quiet line test, on Saturday the connection dropped every few minutes. The noise margin on the hub is 11.6 / 14.7.
Just to top it all off, I have just received the latest bill and have been charged for the engineer’s visit! The engineer didn’t advise me that the visit would be chargeable and there was no fault found with the internal wiring.
I’ve posted my hub stats, and part of the event log.
Thank you.
1. Product name:
BT Home Hub
2. Serial number:
+068342+NQ41048847
3. Firmware version:
Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 06/01/16
4. Board version:
BT Hub 5A
5. DSL uptime:
1 days, 12:34:09
6. Data rate:
3696 / 21412
7. Maximum data rate:
9600 / 40152
8. Noise margin:
11.6 / 14.7
9. Line attenuation:
26.8 / 19.5
10. Signal attenuation:
27.5 / 17.3
11. Data sent/received:
3.8 GB / 22.7 GB
12. Broadband username:
bthomehub@btbroadband.com
13. BT Wi-fi:
No
14. 2.4 GHz Wireless network/SSID:
BTHub5
15. 2.4 GHz Wireless connections:
Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:
WPA2
17. 2.4 GHz Wireless channel:
Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:
BTHub5
19. 5 GHz Wireless connections:
Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:
WPA2
21. 5 GHz Wireless channel:
22. Firewall:
Default
23. MAC Address:
34:8a:ae:c0:0e:f6
24. Modulation:
G.993.2 Annex B
25. Software variant:
AA
26. Boot loader:
1.0.0
5 REPLIES 5
Florence11
Message 2 of 6
Re: low Infinity speed and frequent disconnections - intermittent noise on line
22:03:41, 30 Dec.
(81383.110000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:03:41, 30 Dec.
(81383.100000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
22:03:40, 30 Dec.
(81382.660000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
22:03:38, 30 Dec.
(81380.710000) CWMP: session completed successfully
22:03:38, 30 Dec.
(81380.530000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
22:03:36, 30 Dec.
(81378.830000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:03:36, 30 Dec.
(81378.830000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
22:03:36, 30 Dec.
(81378.390000) CWMP: Initializing transaction for event code 2 PERIODIC
21:31:16, 30 Dec.
(79438.800000) CWMP: session completed successfully
21:31:16, 30 Dec.
(79438.410000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
21:31:14, 30 Dec.
(79436.050000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:31:14, 30 Dec.
(79436.040000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
21:31:13, 30 Dec.
(79435.190000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
21:31:11, 30 Dec.
(79433.550000) CWMP: session completed successfully
21:31:11, 30 Dec.
(79433.370000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
21:31:09, 30 Dec.
(79431.380000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:31:09, 30 Dec.
(79431.370000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
21:31:08, 30 Dec.
(79430.930000) CWMP: Initializing transaction for event code 2 PERIODIC
19:47:31, 30 Dec.
(73213.760000) CWMP: session completed successfully
19:47:31, 30 Dec.
(73213.570000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
19:47:24, 30 Dec.
(73206.300000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
19:47:24, 30 Dec.
(73206.290000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
19:46:34, 30 Dec.
(73156.380000) CWMP: session closed due to error: No response
19:46:31, 30 Dec.
(73153.620000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
19:46:31, 30 Dec.
(73153.610000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
19:45:59, 30 Dec.
(73121.290000) CWMP: session closed due to error: No response
19:45:58, 30 Dec.
(73120.470000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
19:45:58, 30 Dec.
(73120.460000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
19:45:58, 30 Dec.
(73120.010000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
19:09:27, 30 Dec.
(70928.950000) CWMP: session completed successfully
19:09:26, 30 Dec.
(70928.770000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
19:09:22, 30 Dec.
(70924.020000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
19:09:22, 30 Dec.
(70924.010000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
19:08:31, 30 Dec.
(70873.910000) CWMP: session closed due to error: No response
19:08:29, 30 Dec.
(70871.230000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
19:08:29, 30 Dec.
(70871.220000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
19:07:57, 30 Dec.
(70839.860000) CWMP: session closed due to error: No response
19:07:57, 30 Dec.
(70839.000000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
19:07:57, 30 Dec.
(70839.000000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
19:07:56, 30 Dec.
(70838.540000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
19:01:47, 30 Dec.
(70469.880000) CWMP: session completed successfully
19:01:47, 30 Dec.
(70469.550000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
19:01:39, 30 Dec.
(70461.770000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
19:01:39, 30 Dec.
(70461.760000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
BT Wholesale Broadband Performance Test
Broadband Speed Test Results
Download Speed (Mbps):    20.33
Upload Speed (Mbps):          3.14
Ping Latency (ms):             33.63
BT Broadband
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  HighLowHighLow
Featured Products
WBC FTTP Availability Date
VDSL Range A (Clean)73.7552017--Available--------
VDSL Range B (Impacted)57.430198.5--Available--------
FTTP on Demand33030--Available--------
licquorice
Message 3 of 6
You should not have been charged for the visit if no fault was found in your internal wiring, you need to query the charge. There is obviously a line fault that the engineer failed to clear that needs a re-visit by an engineer. Report it as a noisy line fault, once the source of the noise has been cleared your broadband speed will recover.
Florence11
Message 4 of 6
Thank you, I will definitely query the charge.
The only problem with the line fault is that it quickly clears when the weather is dry. I need to catch it in a long spell of rain!
licquorice
Message 5 of 6
Always a problem with that type of fault unfortunately.
Florence11
Message 6 of 6
I do wonder whether the Home Hub is more sensitive to noise on the line, I've been considering replacing it with a TP Link modem/router.
