Newbie
Message 1 of 3
master socket does not work but all other sockets do
hi
over the past week weeks had issue with slow adsl, move din 7 years agao no issues. Just found that plugging into the master sock and test socket gives no deal tone but every socket in the flat works fine. Now flat had a secirty alra, BT RED service which was removed when i moved in years agao. Attached pic can anyone tell whats going on.  Front on the master plate has no wiring so assume thats why does not work.  IMAG0020.jpg
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: master socket does not work but all other sockets do
you need an engineer visit to resolve this problem
Distinguished Guru
Message 3 of 3
The redcare block terminal is only teed across the line.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
