StephanieG
Community Manager - Retired
Message 1 of 4
@mentions
Did you know you can mention a fellow forum member in your post, and they’ll receive an email letting them know they’ve been named in your post?
This is a handy way of posting a reply to someone and making sure they don’t miss it. Just remember it only works when you’re using the Rich Text tab!
How does it work? All you need to do is simply type their username, preceded by the @ symbol.
Step 1:
Type your message and put the “at” symbol in front of the username.
Step 2:
Type the username in full – a drop-down will appear asking you to click on the correct username:
Step 3:
Once you’ve clicked on the username, it will turn blue with a grey background, and look like this:
@mention notifications
You can also decide how often you want to receive an email notification when someone @mentions you. To customise this, all you need to do is:
Click on “My Settings”:
Click on the “Subscriptions & Bookmarks” tab:
Go to “Notification Settings”:
And in the “Email Notifications” section, select from the dropdown for forum when you want to be notified (on all posts, or only for the first post in each topic).
Tags (3)
3 REPLIES 3
StewM
Guru
Message 2 of 4
Re: @mentions
Stephanie, when I have gone into my settings it was automatically set to notify. Have you automatically opted evryone in by default?
Stew
StephanieG
Message 3 of 4
Re: @mentions
Hi Stew,
The @mentions notifications are automatically set to notify “immediately” by default, and this goes for all other subscriptions as well (e.g. if you choose to subscribe to a thread or board).
But if you don’t want it/like it, you can change the frequency to daily, weekly, or to none at all via the drop-down:
StewM
Guru
Message 4 of 4
Re: @mentions
Ok, thanks. I dont want it so set all mine to "Never".
I would have liked the opportunity to "opt in" rather than have to "opt out"!
Stew
