Message 1 of 3
migrate FTTC to BT
Hi
I Currently have 2 FTTC connections with zen internet (1 bt line and 1 zen line) and I am having FTTP installed on Monday 8th June with Cerberus.
My plan is to cancel my zen line / FTTC and move My migrate the FTTC on my BT line to BT fibre 2.
My question is because FTTP is now available will it migrate to FTTC or FTTP (I would like to keep it as FTTC) because according to https://www.thinkbroadband.com/isps/bt/packages/unlimited-bt-infinity-2-broadband-with-weekend-calls “at the bottom” fibre 2 uses WBC FTTC 80/20 VDSL2 or WBC FTTP 80/20 FTTP
2 REPLIES 2
Message 2 of 3
Re: migrate FTTC to BT
I assume with that amount of broadband into a property you are a business customer?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 3
No not business customer just used to connect to my place of work
