jussa21
Message 1 of 8
modem stats
Aarong or webby here are my o/r modem stats what do you think ormodem.jpg
7 REPLIES 7
Message 2 of 8
Re: modem stats
Odd, you have 0 SNR downstream 😕
jussa21
Message 3 of 8
Re: modem stats
webby do you think thats a fault on my line or the modem is f**ked
Message 4 of 8
Re: modem stats
I'm not sure, not seen enough of the modem stats to know whether or not that's a genuine issue or just a reporting error!
jussa21
Message 5 of 8
Re: modem stats
thanks bro
Guru
Message 6 of 8
Re: modem stats
The SNR margins for router stats seem to go from one extreme to another, unless it's affecting your speeds nothing to worry about really.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
jussa21
Message 7 of 8
Re: modem stats
I am still getting speed issues 38 down instead of est of 55 bt checked my can and speed is 56 there but they didn't come to my house not happy so called bt and have an engineer coming on Wednesday just hope they sort it this time or I will go crazy
Guru
Message 8 of 8
Re: modem stats
ok buddy, hope it goes well for ya! let us know how it goes!
