Arkanis36
Message 1 of 59
most of my online games not working
Hey Peeps
Since yesterday most of my online games are not working i can log into them but get lagged out or immidate disconnect,  this happens both on my pc aswell as my wifes pc.  Only game that seems to be workng ok is GW2, the rest dont work (Diablo3, ESO,Starcraft2, plantside2).
Browsing and streaming is fine is just my online games.  Does BT Shape online gaming cause if i did not know better it looks like all my games are being shaped expect for GW2
My speedtest results are fine, http://www.speedtest.net/my-result/5105007311
Things i have tried:
reset the router and reset it to factory default
setup portforwards
Connected directly to the router via Lan cable
switched off wifi aswell as any other devices that was connected
checked for malware and viruses
restarted pc
uninstalled and reinstalled my network card drivers
not sure whats up and bet i am going to have a hard time trying to explain this too telephone support
58 REPLIES 58
john46
Message 2 of 59
Re: most of my online games not working
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
Arkanis36
Message 3 of 59
Hi
Here you go....
john46
Message 4 of 59
Thanks everything there is fine can you please run a tracert using windows command prompt to BBC.co.uk
Arkanis36
Message 5 of 59
Tracing route to bbc.co.uk [212.58.246.79]
over a maximum of 30 hops:
1 2 ms 2 ms 1 ms BThomehub.home [192.168.1.254]
2 * * * Request timed out.
3 * 13 ms 13 ms 31.55.185.177
4 13 ms 13 ms 13 ms 31.55.185.176
5 14 ms 12 ms 13 ms core2-hu0-19-0-1.colindale.ukcore.bt.net [195.99.127.142]
6 14 ms 14 ms 14 ms peer2-et-1-3-0.telehouse.ukcore.bt.net [195.99.127.23]
7 13 ms 16 ms 13 ms 194.74.65.42
8 * * * Request timed out.
9 18 ms 14 ms 14 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
10 15 ms 17 ms 15 ms 132.185.255.165
11 15 ms 15 ms 15 ms 212.58.246.79
Tracing route to google.co.uk [216.58.213.99]
3 * * * Request timed out.
4 13 ms 13 ms 13 ms 31.55.185.184
5 23 ms 23 ms 23 ms core2-hu0-17-0-1.colindale.ukcore.bt.net [195.99.127.156]
6 14 ms 13 ms 13 ms 62.172.103.19
7 13 ms 12 ms 12 ms 109.159.253.67
8 13 ms 13 ms 13 ms 64.233.175.223
9 13 ms 13 ms 13 ms 216.239.57.121
10 13 ms 13 ms 12 ms lhr25s02-in-f99.1e100.net [216.58.213.99]
looks likepack loss on the third hop?
licquorice
Message 6 of 59
No, configured to not respond to pings. Everything looks fine.
Arkanis36
Message 7 of 59
But something is wrong......i have gone through my system with a fine comb there is nothing on my pc that would cause this,  also its a new install of windows 10 which i did a month ago and its doing the exact same thing on my wifes pc.  I have been at this for 2 days now trust me when i say i have tested and troubleshooted any other possiblities.
Is it not possible that for some reason the ports are being shaped or mistaken for p2p??  Why is it happing to all my games expect 1 of them does notmake sense?
john46
Message 8 of 59
BT do not do traffic shaping or restrict the use of P2P
Arkanis36
Message 9 of 59
i will try to find away to test on another connection
john46
Message 10 of 59
I would suggest a google search i found a few problems with one of your games plantside2 likewise   Diablo3
