Brynden
Message 1 of 4
music playlists freeze
Hey all ive had ongoing issues with music Playlists on the BT player app, it doesnt always happen but randomly the box freezes while playing music, i have infinity and i'm connected via ethernet, had this problem since july last year ive just put up with it. All other ondemand works great its just playlists seem to freeze the youview box, anyone else had this ?
3 REPLIES 3
sirjamesp
Message 2 of 4
Re: music playlists freeze
I get the same thing if I try "play all episodes" from any series on channel 5 catch-up - perhaps the same bug as with music playlists?
Steve_M
BT TV Expert
Message 3 of 4
Hi Brynden,
What software versions do you have?
Steve
Brynden
Message 4 of 4
Hi Steve I'm using
Manufacturer 15.11.0
Component softwate 2.1.14
Platform config 714
ISP 90
Ive had many updates since the problem started inJuly last year, as i say everything else works fine its just on playlists the box randomly hangs there, Ive also used maintenace mode many times to reset it and it works for a week or two before the bug comes back, I have the orginal humax branded youview box.
