billy06
Message 1 of 16
my infinity is suffering from a slow death
hi, after having infinity option 2 for 18 months with relatively no problems last wednesday my connection dropped which it always has done evey now and then, but since then speed have been really slow, i used to get 72Mbps down and 17Mbps up  now during the day i get
1. Best Effort Test: -provides background information.
Download Speed
20.59 Mbps
0 Mbps 77.43 Mbps
Max Achievable Speed
Download speedachieved during the test was - 20.59 Mbps
For your connection, the acceptable range of speedsis 60 Mbps-77.43 Mbps .
Additional Information:
IP Profile for your line is - 77.43 Mbps
2. Upstream Test: -provides background information.
Upload Speed
0.01 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 0.01Mbps
Upstream Rate IP profile on your line is - 20 Mbps
Your service was found to be performing poorly.
Please raise a fault with your service provider, stating that the BT Performance Tester tool indicates poor service throughput performance after the third test.
in the evenings i'm lucky to get 4Mbps down, i have raised the issue but the status is now showing as cleared, does this mean i need to contact Bt again?
15 REPLIES 15
Keith_Beddoe
Message 2 of 16
Re: my infinity is suffering from a slow death
Were those speed tests done using a direct Ethernet cable from the home hub, to the computer?
billy06
Message 3 of 16
yes direct ethernet from pc to HH , nothing else connected via cable or wireless, have tried different ports , different cable, also tried using laptop via ethernet with simular results, like i say all was fine for the last 18 months until the drop out last wednesday
ptan
Message 4 of 16
Hi billy
You could have a fault on the line. Is the line crackly at all?
ptan
billy06
Message 5 of 16
no the line seems fine
ptan
Message 6 of 16
Hi billy
OK, your profile shows that your expected rate should be up there in the late 70s'. It may be worth calling the BT helpline - I am not sure, but I think this number will get you a UK based call centre 0800 800 030
ptan
billy06
Message 7 of 16
hi i have been on the phone to india again and after repeating all the same tests that were done previously an engineer is booked for wednesday afternoon
ptan
Message 8 of 16
Hi billy
That is good. At least when the engineer comes out he can do a full test for you.
ptan
billy06
Message 9 of 16
yes after arranging cover for the afternoon i just hope all can be sorted then
mikesworld
Message 10 of 16
Good luck reguarding the engineer turning up.
