hyattjon
Message 1 of 6
my own servers pop3 is blocked
I have a website and a mail server.
Over the last few days I am getting failed login responses and failed authentication from it, yet it works from the webmail page sometimes.The mail program settings have not been changed and are correct as it sometimes but rarely POPs ok, but fails to SMTP.
Does BT block third party pop accounts?
I ask because I find my BT IP adress is listed on the spamhaus PBL, and my hosting company heartinternet say the server is responding OK when tested.
5 REPLIES 5
hyattjon
Message 2 of 6
Re: my IP address is blacklisted and own servers pop3 is blocked
on further searches I find my IP adresss is blacklisted at 3 places
http://www.mxtoolbox.com/SuperTool.aspx?action=blacklist%3a81.159.49.98
How can I get it removed or change it?
I can no longer access my pop3 server and a few webpages including webmail to my own server fail to respond.
Quote from my Hosting company (Heart internet) support:
...[ You really need to speak to a senior member of support at BT (I fear the 1st level support you may first get through to may not have the required knowledge to adequately answer and resolve this) to get these blacklistings removed or better - assign you a new IP address that isn't blocked.]...
Who do I contact please?
vofsanity2
Recognised Expert
Message 3 of 6
Jon,
You should only need to disconnect and reconnect your router to the internet to be allocated a new IP address.
It is probable that a previous machine  with that IP address has been used either consciously or otherwise to send spam.
john46
Message 4 of 6
hi could you edit out your email address this is a public forum
hyattjon
Message 5 of 6
done
hyattjon
Message 6 of 6
Yes, I know how to renew my IP address but I seem to keep getting allocated from the same block and most are on one list or another. I have got around the problem by using all my SMTP settings on port 587 instead of port 25 and not using the webmail page.
Not a great fix but it keeps everybody happy it seems.
I am disappointed that BT seem to think it a good idea to keep adding it's customers IP blocks to Policy Block Lists because eventually it will force it's customers to abandon third party mail servers. I guess BT must have a big spam and botnet problem.
Sledgehammer to crack a nut, but that's big business for you.
Consider the question solved.
