Message 1 of 12
my speed from my exchange droped from 14mb to 4 mp
Hi my speed from my exchange droped from 14mb to around 4mb.
i live 0.9 miles away from exchange and should be getting around 14mb.
i joined bt friday the 16/5/14 and was getting 14mb from exchange to my hub,
come Monday i was getting 4 mb from my exchange to my hub .
11 REPLIES 11
Moderator
Moderator
Message 2 of 12
Re: my speed from my exchange droped from 14mb to 4 mp
Hi gdvsgeorge and welcome.
Can you try running the speed test and post your results, including the further diagnostics. I'm sure we can help you with this once we have the details.
Cheers
David
Message 3 of 12
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 4 of 12
what am saying the speed is leaving your exchange at 4.5mb get to my hub around 4mb
it should be leaving your exchange 15mb and getting to me around 14mb.
i can under stand if it's leaving the exchange at 14mb and getting to me at 4mb but is not.
Message 5 of 12
really need you to post some adsl stats and also btspeedtester diagnostic results to show the problem
Message 6 of 12
1. Best Effort Test: -provides background information.
Download Speed
4.06 Mbps
0 Mbps 4 Mbps
Max Achievable Speed
Download speedachieved during the test was - 4.06 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 4 Mbps
2. Upstream Test: -provides background information.
Upload Speed
0.97 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.97Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
We have identified that you have additional services enabled on you broadband line, please click continue to run advanced service tests.
Message 7 of 12
from that you are on adsl2/2+ and your profile is 4mb which is limiting your download speed  this could more than likley be due to conenction problemwith either line dropping or manual resets or bothe which have resulted in a lower conenction speed and higher noise margin.  if done often enough it could easily be a banded profile - but need adsl router stats to see
http://www.plus.net/support/broadband/speed_guide/broadband_terminology.shtml
your profile is 88.2% of conenction speed so to get higher profile you need a faster conenction speed
Message 8 of 12
1. Product name: BT Home Hub
2. Serial number: +068340+NQ41337189
3. Firmware version: Software version 4.7.5.1.83.8.130.1.17 (Type A) Last updated 17/05/14
4. Board version: BT Hub 4A
5. ADSL uptime: 0 days, 02:55:37
6. Bandwidth: 1163 / 4536
7. Data sent/received: 48.9 MB / 1.0 GB
8. Broadband username: bthomehub@btbroadband.com
9. BT FON: No
10. 2.4 GHz Wireless network/SSID: BTHub4-27WT
11. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (Recommended)) 20 MHz, WPS enabled
12. 2.4 GHz Wireless security: WPA and WPA2
13. 2.4 GHz Wireless channel: Automatic / 11
14. 5 GHz Wireless network/SSID: BTHub4-27WT
15. 5 GHz Wireless connections: Enabled (802.11 n 40 MHz (Recommended)) 20/40 MHz, WPS enabled
16. 5 GHz Wireless security: WPA2
17. 5 GHz Wireless channel: Automatic / 40
18. Firewall: Default
19. MAC Address: 34:8a:ae:dc:80:f4
20. VPI/VCI: 0 / 38
21. Modulation: G.992.5 Annex A
22. Latency type: Interleaved
23. Software variant: -
24. Boot loader:
Message 9 of 12
06:19:56, 19 May. ( 116.660000) DSL noise margin: 5.90 dB upstream, 24.60 dB downstream
06:19:55, 19 May. ( 115.340000) DSL line rate: 1144 Kbps upstream, 4536 Kbps downstream
06:55:24, 19 May. ( 101.010000) DSL noise margin: 5.90 dB upstream, 24.60 dB downstream
06:55:23, 19 May. ( 99.840000) DSL line rate: 1167 Kbps upstream, 4536 Kbps downstream
15:19:43, 21 May. (33993.380000) DSL noise margin: 5.90 dB upstream, 24.60 dB downstream
15:19:42, 21 May. (33992.160000) DSL line rate: 1163 Kbps upstream, 4536 Kbps downstream
15:16:54, 21 May. (33824.540000) DSL is down after 561 minutes uptime
15:16:54, 21 May. (33824.540000) ETHoA is down after 561 minutes uptime
15:16:53, 21 May. (33822.990000) PPPoA is down after 561 minutes uptime [Waiting for Underlying Connection (WAN DSL -​ Up)]
Message 10 of 12
so your connection speed is now 4.5mb hence the low profile and low download speed.  your connection time is <3hrs is that due to router dropping connection or manual reset?
are you connected directly via a filter to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
from your stats your noise margin is very high as normal about 6db and as thought before you are in a banded profile and now need to stay connected 24/7 for 3+ days and banding should release with a drop in noise margin and increase in connection speed
If still no change after 3+ days conenction time then repost the adsl stats again showing the connection time of 3 days and mods will help get you out of banding
