Message 1 of 8
need mod help with ip profile
Hi all,
Ive been having problems with the speed for the past week, i have consistently received speeds of around 1meg until now.
I have a suspicion that my ip profile may be stuck, if a moderator could help that would be great.
Here's my latest stats, i have a bt  business hub.
I have always had quite a high noise margin but it has never been a problem.
many thanks
System  Broadband Link  Local NetworkDigital VoiceFirewallParental Controls
View Broadband Link Details
Help
Details
DSL Connection Details
DSL Line (Wire Pair):Line 1 (inner pair)
Protocol:G.DMT Annex A
Downstream Rate:1280 kbps
Upstream Rate:448 kbps
Channel:Interleaved
Current Noise Margin:15.0 dB (Downstream) 18.0 dB (Upstream)
Current Attenuation:63.0 dB (Downstream) 31.5 dB (Upstream)
Current Output Power:17.1 dBm (Downstream) 12.5 dBm (Upstream)
DSLAM Vendor Information:Country: {0xB5} Vendor: {TSTC} Specific: {0x00}
PVC Info:0/38
Internet Connection Details
Connection Type:PPPoA
Username:bthomehub@btbroadband.com
Internet Address:
Subnet Mask:
Default Gateway:217.47.109.250
Primary Domain Name Server:213.120.234.2
Secondary Domain Name Server:213.120.234.38
Domain:
Maximum Transmission Unit (MTU):1500
Gateway Ping:Successful
DNS Communication:Successful
Configuration Server Post:Successful
View Broadband Link Statistics
Help
Transmit and Receive Data
IPBytes Packets Errors
Transmit:56398392 318676 0
Receive:385466716 374617 0
Help
Data Errors
Statistics
Collected for 3 days 18:54:59
 Since ResetCurrent 24-Hour IntervalCurrent 15-Minute IntervalTime Since Last Event
ATM Cell Header Errors:19291302:35:30
ATM Loss of Cell Delineation:1464001 day 13:44:42
DSL Link Retrains:8002 days 22:06:36
DSL Training Errors:8003 days 6:12:12
DSL Training Timeouts:0000:00:00
DSL Loss of Framing Failures:18003 days 6:13:14
DSL Loss of Signal Failures:0000:00:00
DSL Loss of Power Failures:0000:00:00
DSL Loss of Margin Failures:0000:00:00
DSL Cumulative Errored Seconds:262902:35:30
DSL Severely Errored Seconds:31003 days 6:13:14
DSL Corrected Blocks:736951120:01:13
DSL Uncorrected Blocks:20741302:35:30
ISP Connection Establishment:1110:02:29
7 REPLIES 7
Message 2 of 8
Re: need mod help with ip profile
and heres my speed test results
1. Best Effort Test: -provides background information.
 Download  Speed
 0.24 Mbps
Download speedachieved during the test was - 0.24 Mbps For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps. Additional Information: Your DSL Connection Rate :1.28 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM) IP Profile for your line is - 0.25 Mbps
Message 3 of 8
your profile will correct itself automaitcally provided you remain connected 24/7 for 3/5 days - just no resets  you profile is low due to a previously low conenction speed
try quiet line test for any line noise  dial 17070 option 2  should hear nothing and best with corded phone  if cordless then dull hum normal
Message 4 of 8
thank you for quick reply imjolly,
iv'e tried all the usual tests of quiet line ect, as i said i've consistantely had speeds of over 1 meg previous to this week.
I've also had a solid connection for over 3 days but i will take your advice and wait a few more days to see if it improves.
many thanks
Message 5 of 8
you must have had problems with drops in connection and/or manual resets resulting in a lower speed and the subsequent lower profile.
with your high noise margin it would give you a faster speed if you could get that down to normal 6db
are you connected to master or preferably the test socket?  do you have any extension sockets in other rooms
Message 6 of 8
I'm connected to the main socket with no extensions in the house, i agree that last week there must of been some drop in connection, but everything seems stable now. I've always had quiet a high noise margin but i still managed to get good speeds for my line attenuation.
I will try and be patient and see if the 3-5 day rule will work for me.
thanks
Message 7 of 8
Speed has been restored to normal, ip profile increased. Patience was all that was needed, imjolly was correct in that your ip profile does correct itself if a stable line is held for 3-5 days.
Or if your very paranoid maybe the mods read people's posts here and get it sorted on the QT, either way problem solved, thanks to imjolly for help.
Message 8 of 8
glad it's fixed and your speed is back - patience was all that was needed but easier said tha doneSmiley Wink
