Message 1 of 3
new Phone question
Hi all
Apologies if sounds stupid but I am on BT mobile for 3 sims, all happy and good.  Getting my wife a new phone (unlocked) for her birthday, I take it you don't have to re register etc, just pop the sim from the old phone in the new one ?
Thanks in advance
2 REPLIES 2
Message 2 of 3
Re: new Phone question
If the phone is unlocked to any network, just pop the sim in and you're ready to go.
I'd advise checking the sim size though, if the existing handset takes a different size sim, you might need to order a free replacement small should be ok as BT have sent universal sims for years, you could push out the smaller size.
Message 3 of 3
ah brilliant, I thought that was the case. Sim size should be fine as going from and old iPhone SE to a new iPhone SE.
Thanks for the speedy reply
