snowy52
Message 1 of 5
new bt hub
hi all ive been with bt for a couple of years now and ive got the bthub 2 just wanted to know if i bought the new home hub which is on ebay for 30 pound s plus will it work on my system. bt want 90 pounds for the new one
4 REPLIES 4
Message 2 of 5
Re: new bt hub
It should work, provided it is not faulty, however you will lose the ability to use broadband talk, and any hub phones will not work with it.
Also there are still issues with port forwarding on the new hub, which may present problems if you play online games, or have eny external devices like IP cameras.
snowy52
Message 3 of 5
Re: new bt hub
thanks keith for your help
justatwork
Message 4 of 5
Re: new bt hub
You can get the Hub half price if your an existing BT customer its just £46
snowy52
Message 5 of 5
Re: new bt hub
hi justatwork already phoned bt they want £90 is there a number you can ring to get the new hub thanks
