Message 1 of 6
new connection
hi
this is my first post has a new infinity customer, i went live friday 31.03 but my connection is unstable it varies from
0.5 to 38.5.
can anybody advise on the eratic speed.
regards
pugh
5 REPLIES 5
Message 2 of 6
Re: new connection
Are you testing the speed wired or wirelessly?
Wireless is not really stable enough to always provide accurate, consistent results.
Message 3 of 6
Re: new connection
Are you testing wireless or wired? You should always do speed tests with a wired connection.
Go to BT Speed Tester, run a test and come back and post your results.
Message 4 of 6
Re: new connection
hi i run mainly wireless around the house but i connect directly to the hub for speed testing, the max speed is ok it's just very unstable.
regards
Message 5 of 6
Re: new connection
What site have you been using to test the speed? Have you ensured that no other devices/programs are using the internet at the time you're running the test?
Message 6 of 6
Re: new connection
Same here. Wired connection. Connects at 37meg and then after a random amount of time, drops to 0.58. I have to restart the hub/pc to resolve it. I have to restart about 20 times a day.
