Just bought a netgear d7000, is there any way that anyone knows to view the max attainable data rate?
Could view this on the helpdesk tab on the homehub, but can't see where to view it on the d7000.
Solved! Go to Solution.
I think you need to be able to telnet into router to get more stats google is your friend
sorted thanks
