leannehardy41
Message 1 of 2
no signal
Hi I seem to be having trouble with my signal f or the past two days. It won't register on the network but it had when I got it. .my phone is fine as I tried another Sim and it's fine my partners BT Sim has no problem either just mine
1 REPLY 1
Fusionmoth
Message 2 of 2
Re: no signal
Was the other sim tested a BT sim? Seems peculiar.
Is this everywhere you go or specific to just one location?
If you take the sim out and touch it with skin contact and reinsert does that help? (You'd be amazed how a big of static on the sim contact can make it stop)
If this doesn't work, and you are having the same problem everywhere and the other sim tested is a BT sim, then that only leaves 2 common things - your BT account and the sim card.
I'd give them a ring, get them to check there's nothing abnormal on your account that would stop it from working, and if there's nothing, if get a replacement SIM card
