marlboro20
Message 1 of 8
no wi-fi....but old adsl router works !
hi all....my tp link archer d2 lost the internet signal, so i reset it, changed everthing i could,diagnostics say nothing wrong with phone line etc....plugged in an old router with ethernet cable and it works. but comes up with error 651..any ideas  please ?...thanks
7 REPLIES 7
Liam_
Recognised Expert
Message 2 of 8
Re: no wi-fi....but old adsl router works !
Have a look here:
http://www.geeksgyaan.com/2015/04/fix-error-651.html
If that doesn't help Google for 'error 651'.
jiten634
Message 3 of 8
You can try these new 8 methods  to fix Connection Failed with Error 651 in Windows.
I hope it will helpful for you. Because i fix my error 651 by using 5th method.
jaidixit007
Message 4 of 8
Most of the time the issue is with your router's plug. By simply re-inserting it, you can resolve this issue. Still if the issue remains same then give a try to these solutions.
1. https://answers.microsoft.com/en-us/windows/forum/windows_7-networking/error-651-in-windows-7/650774...
2. https://www.techwhoop.com/fix-error-651/
Hope it helps. Still if you're facing any issue then let me know.
gg30340
Message 5 of 8
The OP posted this three months ago so you may not get a reply from him and hopefully he has resolved the problem but your answer may be helpful to others.
josh92
Message 6 of 8
Sometimes by Updating WiFi Drivers can solve the issue. Check out this info page to update and reinstall your WiFi router Driver which can solve the Error - https://techcortex.com/how-to-reinstall-wireless-driver-in-windows-10/
licquorice
Message 7 of 8
Good advice, but I suspect after a year the OP has got it sorted
josh92
Message 8 of 8
That's great. I hope so.
