Message 11 of 35
Re: not getting anywhere on helpline - speed/noise reducing regularly
For now just leave every thing alone and keep an eye on the noise margin during the evening
Guru
Message 12 of 35
You've had mine .... but what do I know?
It only worked for 2 years on mine, the way I've stipulated. before I went to ADSL2.
Guru
Message 13 of 35
He does .....
And it drops .....
Message 14 of 35
Like you posted before Roger unless the Noise margin is set to 9dB this will continue to happen my comment on keeping an eye on it was that after the reset the noise margin had goes back to 6dB again and to see if it started dropping again during the evening
Guru
Message 15 of 35
It will continue to go down .... that's what it doing.
His target 6db is eroding till it gets that low, bitloading isn't efficient, then it's dropping and starting over again.
His 4db and less won't sustain the IP stream at night, hence my suggestion.
And if he has dslam 9db set, it will erode the same, but to about 6-7db, where it WILL bitload at night.
Then .... it won't drop.    🙂
Message 16 of 35
so should the OP be put in touch with the mod team and get the reset carried out
Guru
Message 17 of 35
The moderators have the capability to do it ....
Request it through the mods, with a link to this thread.
But of course, it's the OP's decision.
And like I said previously, he will get a slightly lower sync at target 9, but after the dslam has trained a while on it, it will settle down and improve once line history has established.
Losing some sync rate is not important, it's throughput that's important, and his will improve at night, and the daytime throughput that is lost owing to that slight loss in sync, will hardly be noticeable.
Message 18 of 35
I suggest you contact the forum mods they should be able to get this problem sorted for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderators
Guru
Message 19 of 35
It's like speaking through an interpreter ..... 🙂
Wibble
Message 20 of 35
calm down peeps - its only broadband Smiley Indifferent
it was fluctuating last night between 8.1 and 7.8....although speed is good
its settled down to 6.9 this morning
i'll contact the mods and let you know the final outcome
