Message 21 of 35
Re: not getting anywhere on helpline - speed/noise reducing regularly
please keep us informed on your progress
Guru
Message 22 of 35
@Wibble wrote:
calm down peeps - its only broadband Smiley Indifferent
it was fluctuating last night between 8.1 and 7.8....although speed is good
its settled down to 6.9 this morning
i'll contact the mods and let you know the final outcome
What do the stats say ... it may already be using 9db from what you're saying.
Wibble
Message 23 of 35
Connection Information
Line state:Connected
Connection time:0 days, 16:54:01
Downstream:3.563 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):8.6 dB / 18.0 dB
Line attenuation (Down/Up):56.6 dB / 31.5 dB
Output power (Down/Up):18.9 dBm / 12.5 dBm
FEC Events (Down/Up):119294 / 3
CRC Events (Down/Up):374 / 5
Download speedachieved during the test was - 3.42 Mbps
 For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
 IP Profile for your line is - 3.22 Mbps
Upload speed achieved during the test was - 0.35Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.45 Mbps
Message 24 of 35
as RogerB suggested it certainly looks like line has reset noise margin to 9db
Guru
Message 25 of 35
In which case .... you need to do nothing, it's been done for you ... automatically.
Wibble
Message 26 of 35
just to let you know that Mods have increased target SNR to 9db.  i noticed that "interleaving" has switched to "fast".
speed has only reduced to 3.08Mps (3.74 at its peak previously)
see how it goes and i'll let you know how stablity goes.
Message 27 of 35
ok please keep us posted on your progress interleaving may come back on if the connection needs it
Wibble
Message 28 of 35
Back again - - - - not getting much better.
Before i go back to mods, anyone got any thoughts?
just a quick refresh of events - i had a problem with the noise margin continually dropping to the point that speed was unbearable, and eventually line became unstable and either auto restarted the hub, or i needed to restart it as it locked up.  Mods reset to get lower speed etc but hpefully stablise the noise margin.....
On a good day i will get a BTspeedtest of 3.07Mbps.  not quite as good as the 3.7 i got before they tweaked the line....and certainly not close the the 4Mbps i got when the line was first installed in July.
its been a few weeks, and i have to reset the router about every 11 days when speed just becomes terrible.  here are the stats today....pretty much the same as every 11-12 days.  So its due a reset else it will just sit there without any change to the point of dialup style page loading.
 Download speedachieved during the test was - 1.36 Mbps
 IP Profile for your line is - 2.91 Mbps
Connection time:11 days, 04:47:52
Downstream:3.219 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):3.1 dB / 18.0 dB
Line attenuation (Down/Up):55.7 dB / 31.5 dB
Output power (Down/Up):18.6 dBm / 12.5 dBm
FEC Events (Down/Up):0 / 125
CRC Events (Down/Up):781571 / 232
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):227006 / 88
Error Seconds (Local/Remote):68532 / 258
Guru
Message 29 of 35
What does the downstream noise margin come back to .... after a reset?
Wibble
Message 30 of 35
it normally comes back on about 8 to 9 immeadiatly after reset then settles down to around 6 or 7 after 24 hours.
It will gradually start creaping down after about day 8 to around 5 or 6dB
It only becomes a problem on day 10 or 11 were it will run around 3.5 - 4.5dB
currently settled at 7.6dB having been reset 14hrs ago
