alex875
Message 1 of 34
over the last 2 days my speed has been a constant 0.13 mb/s
any help would be great not rang bt yet,  this is very slow i was getting speeds of 3 meg over last few years,
33 REPLIES 33
Message 2 of 34
Re: over the last 2 days my speed has been a constant 0.13 mb/s
welcome to the forum
can you post the adsl stats from your router may need to show detail to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z) and run btspeedtester http://speedtester.bt.com and post the results. Someone may then be able to offer assistance
alex875
Message 3 of 34
hi i did a test on speedtesterb.bt.com results below.
Download speedachieved during the test was - 114 Kbps
 For your connection, the acceptable range of speeds is 50-250 Kbps.
 Additional Information:
 Your DSL Connection Rate :704 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 135 Kbps
i tried to enter 192.168.1.254 and it takes me to bing search page????
what do i do now? thank you
Tags (1)
Message 4 of 34
what router are you using?
alex875
Message 5 of 34
ok its working now im in on bt home hubive got home, services, settings and trobleshooting, to choose from where and what do i do now? thanks
Message 6 of 34
trying to find adsl stats - i don't use a hub so not sure
alex875
Message 7 of 34
ok i found it heres what it says:
Line stateConnected
Connection time0 days, 0:09:13
Downstream704 Kbps
Upstream448 Kbps
ADSL settings<script type="text/javascript">// createTable("normal", trClass, td3, td4); // </script>
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)10.9 dB / 21.0 dB
Line attenuation (Down/Up)40.0 dB / 22.0 dB
Output power (Down/Up)15.4 dBm / 12.3 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)168 / 0
CRC Errors (Down/Up)0 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)0
Message 8 of 34
your connection time is only 9min have you been having connection problems with the hub resetting or have you been resetting the hub in the hope your connection will improve?  worst thing for the hub is being reset especially a few times in a short space of time.
are you connected to the master or test socket or somewhere else?
check this post for ideas
http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
alex875
Message 9 of 34
hi it says 9 mins as i did a reset default, i am connected to the master, its been fine for 2 years since fitted, but 2 days ago bang its down, cant watch you tube etc  was there anything else you notiched? what should i do now contact bt or wait.
Message 10 of 34
does the bottom half of your master socket detach and leave the test socket behind?   If so try connecting to the test socket - do you have extension sockets in your home?  if so have you disconnected the orange bellwire from your sockets as it can act like an aerial for noise.  have you tried replacing the filter as they don't last forever?
