foxyblue62
Newbie
Message 1 of 3
password to connect to hub
Okay here we go...........only been with bt a month and my daughter wanted to connect wirelessly to the hub..............doh I cant remember what the password is or where to find it........ my phone connects with no problems...help x
2 REPLIES 2
Message 2 of 3
Re: password to connect to hub
if you have the HH3 and have not changed the wireless password then it is on the pullout on the back of the hub.
if your phone connects can you not display the wireless password on your phone?
Distinguished Guru
Message 3 of 3
Hi.
Are you after the wireless key or the Hub admin password.
if the hub admin password, you might have to do a factory reset, if its the wireless key and its the HH3 it is on the bottom of the router or on the tab.
toekneem
(EASBF)
