Message 11 of 29
Re: ping on copper v ping on fibre
Odd, do you have a neighbour with a BT line, try entering their number to see if you get the same result.
Message 12 of 29
And its a Type A
Message 13 of 29
BT BROADBAND AVAILABILITY CHECKER
Telephone Number 01394 xxxxxx on Exchange WOODBRIDGE is served by Cabinet 22
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate(Mbps) Downstream Range(Mbps)Availability Date
                                   High Low High Low
FTTC Range A (Clean)      38.8  30  7.6  5.7 -- Available
FTTC Range B (Impacted) 33.1  18  7.6  3.7 -- Available
WBC ADSL 2+ Up to 1 -- 1 to 3.5 Available
ADSL Max Up to 1 -- 0.75 to 2.5 Available
WBC Fixed Rate 0.5 -- -- Available
Other Offerings
Fibre Multicast -- -- -- Available
Copper Multicast -- -- -- Available
It appears that checker didn't like my works computer 😉
Message 14 of 29
Looks like you are on an Huawei cabinet which probably has G.Inp enabled but your HH5A doesn't support it.
Message 15 of 29
So changing to a type B might be the way forward?
(just curious ...how sure are you of the cabinet's manufacturer?)
Message 16 of 29
your cab is Huawei
Message 17 of 29
Thanks imjolly and liqurice...
So reading the g.inp thread linked to earlier (I'm upto page 12) it seems a type B homehub is the solution.
Message 18 of 29
or possibly better an openreach modem hg612 from auction
Message 19 of 29
Or a third party router. Wouldn't recommend paying for a Home Hub!!
Message 20 of 29
Sooooo ...who at BT do I start badgering for a replacement?
