Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
So the Unlocked ECI/r are relativity plug an play apart from the line info.
Just they looked a bit complex - though they need more configuring , me over reasearching :oops:
Thats one good thing about the HH5 is the line info help page. BT just need toget the thing stable!
Thanks,
Appreachte the help as its all quite new.
Thought the HH5 would be ideal but at the moment its needs some major fixes.
well i've jumped from 40 down/6 up to 51 down/6 up and at same time got rid of the wireless problems i was having with my apple gear.
Purchased a new modem/router plugged it in on friday connection rate went up right away and has increased since then, no connection loss and wireless is working perfect on all devices. Got access to full line stats as well.
kenny
ZyXEL SBG3300 N
Not cheap at around £150 but glad i got it now
kenny
@Kenny wrote:ZyXEL SBG3300 N
Nice
Thanks Kenny for the heads up. Please let me know in a few days if
this new modem+router is definitely the best for your line and
definitely keeps your line stable.
I might get one of those myself depending on your outcome.
will keep you updated, its a lot of money but if stays the same then it will be worth it
Downstream Upstream
Attenuation (dB): 24.8 0.0
Connection speed (kbps): 49744 6045
SNR margin (dB): 5.2 6.1
kenny
Downstream Upstream
kenny
Thanks Kenny.
I might get one in under two weeks time if you get good results with this modem+router and it manages
to keep your connection connected with a lot less dropouts at your lines maximum speed.
What settings did you use to get it working with BT Infinity? and did you update to the latest firmware?
