Message 211 of 366
Re: planning to get myself an unlocked openreach modem
The Netgear R7000 Nighthawk around £160 .
Message 212 of 366
i had a boost engineer out who couldnt find a fault but took interleave off for me. come 3am and one router reset caused it to go back on, all because of a fimrware update.... there was a fault at the exchange that has apparently been fixed but i dont see any improvements what so ever. i get huge ping spikes and high packet loss when i download making gaming unusable. i thought with vdsl you were supposed to be able to do more at one time, i guess not, well not with bt anyway, sky fibre is a million times better.
Message 213 of 366
Can anyone give me a heads up and tell me if my stats are ok..
Mike,
Message 214 of 366
Show me them mike
Message 215 of 366
I seen them on the other page, yeah they look ok mike, noise margins are around the 6dB mark and speeds are ok.
Message 216 of 366
Thanks for that, I wasnt. sure , lots of sir and line attenuation and stuff,,
Thanks mike
Distinguished Guru
Message 217 of 366
Are the speeds anywhere near the estimate?
If not, I'll try again 🙂
Newbie
Message 218 of 366
So I have in my past had a QA job at a software company and decided to try each setting on and off one-by-one. I've just turned of UPnP which also turned the UPnP extended security and I've not disconnected for over 2 hours, I even managed to play a FIFA 15 game online. I was disconnecting every 15ish minutes. I'll report back on how this goes but if anyone else is having their connection dropped maybe you could try this as well? Let me know if you do and if it works 🙂
Edit: On the Home Hub 5 plus I factory reset
Distinguished Guru
Message 219 of 366
Is that on the Openreach Modem?
Newbie
Message 220 of 366
It was on the Home Hub 5  🙂
