Barry57
Expert
Message 291 of 366
Re: planning to get myself an unlocked openreach modem
  tyke2806 wrote: "telnet in to the router I am not able to get any more detailed stats. I can log in fine, but then nothing seems to work."
The best tip i came across from ray's link on kitz was to use a programme called PuTTY instead of using windows telnet
I have the basic commands (get stat /interleave/help ect) in a windows notepad file  so I can just copy the lines directly into PuTTY and jobs a good'n.
Its far easier for me than try into to type things 🙂
Barry57
Expert
Message 292 of 366
"We're aware of an issue affecting the BT Home Hub 5A which could be causing performance issues with a small number of our customers' internet connections. The symptoms these customers may have include occasional loss of wi-fi and broadband connection."
Just again want to "doff my cap"" to the Guru's who recommended this thread. 🙂
Mine line is rock soild with the unlocked eci/r & Tomato linksys router.
No updates , dissconnects , calling home, dropping leases or any other mischief the hh5  (now  ^confirmed^) gets up to........
Ray , gg30340 and pippincp where right all along with the hh5's issues.
mykspence
Message 293 of 366
'Small number', what ****** planet are they on!?
Barry57
Expert
Message 294 of 366
".....extra changes..... based on feedback from our customer test group.This means it is taking a little longer to deploy the fix and for you to see the improved performance. We are working around the clock to ensure it is done asap, please leave your BT Home Hub on to ensure it receives the fix."
Might take a while then........
Still agree with the Guru's that the quick and easy fix is not to use it 🙂
I wonder if they've broken it trying to get the hh5 work with the new "transmision technology" the people on kitz are excited about?
No wonder the openreach engineer said  leave it in the cupboard.....
My old Tomato Linksys seems light years ahead now.
ray_dorset
Distinguished Guru
Message 295 of 366
I think they're trying to implement the EU standby power saving directive.
If not, I'll try again 🙂
gg30340
Message 296 of 366
I haven't read the directive in full but I doubt that it has to be implemented retrospectively so I would imagine that no company would go to the bother of trying to update existing software or hardware to comply if it wasn't necessary.
Barry57
Expert
Message 297 of 366
Though it did already met the power regs ?
Least it will keep openreach busy over the next few months reseting dlms 🙂
I'm most feel left out as the lines as dull as dishwater using separates. I now fully appreciate why the more bussiness orientated isp's still pay openreach to install modems.
ray_dorset
Distinguished Guru
Message 298 of 366
Unlikely, the regualtions are a can of worms that is kicked down the road every 12 months or so.
http://www.eceee.org/ecodesign/products/Lot26_networked_standby_losses/REG_801-2013_Standby_losses.p...
19nbg71
Expert
Message 299 of 366
"trying"
don't they have beta testers ? and if they do why havn't they utilised the testing?or do they just chuck any old thing at the user and cross their fingers...a total shambles in my eye and i haven't even got a hh5....
ray_dorset
Distinguished Guru
Message 300 of 366
Say hello to your fellow beta testers...
