jamesant
Newbie
Message 1 of 4
playstation 4 wont connect by wifi big bt problem help please
Just brought a ps4 and can not get it to connect to the Internet by wifi works with a lan cable but refuses to take the wifi password. Contacted sony and they said it was bt fault so spent two days being messed around by them they admitted there is a problem and have had a few ps4 owners and they could fix it but only if I took out a £11 a month service contract with them disgusting. Has anyone else managed to fix this and if so how driving me mad. Oh I have a home hub 3 if that makes a difference
3 REPLIES 3
Message 2 of 4
Re: playstation 4 wont connect by wifi big bt problem help please
jamesant
Newbie
Message 3 of 4
John that does not work only works on the ps3 the ps4 does not let you choose wep in the custom screen sets up totally differently but thanks for trying
Message 4 of 4
personally if you are considering any serious gaming you will be better off using a wired connection then a wireless one
