djclix
Message 1 of 4
please can someone check my homehum stats and tell me whats wrong
Downstream832 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeInterleaved
Noise margin (Down/Up)9.0 dB / 21.0 dB
Line attenuation (Down/Up)56.8 dB / 31.5 dB
Output power (Down/Up)1.5 dBm / 1.6 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)2381 / 0
CRC Errors (Down/Up)1 / 0
HEC Errors (Down/Up)0 / 0
Error Seconds (Local/Remote)1 / 0
3 REPLIES 3
Message 2 of 4
Re: please can someone check my homehum stats and tell me whats wrong
you have missed off the connection time
are you having connection problems - line dropping or manual resets?
speed is low for your attenuation - are you conencted to master or test socket
have you tried the quiet line test?
djclix
Message 3 of 4
Spoiler
Having a nightmare. Only get 0.5 speed. Up to recently it was 3.0+ mbps. 3rd BT engineer on site today. Gave me a Home Hub 3 but still no change to the speed. again he said he would get my ip profile reset, and again for the 4th time nothing has happened. No change. I find it funny that no-one in the world knows what the problem is. Not on the forums, not in India at the callcentres and not in the UK. Surely there is not that much to it.
Could it be that I have a "locked" line or locked internet speed. One engineer said its possible to lock out at 0.13mbps and think he gave another common figure, was s "lock"out thing.??? Thanks
Message 4 of 4
can you post the answers to the points in my last post?
can you run btspeedtester and post the results.
it is difficult to give constructive suggestions without information - sorry
