josh260893
Newbie
Message 1 of 2
port forwarding
i have a bt home hub v2 router. untill recently i only had one xbox then decided to get another since the first was only a family xbox. They both connect fine to the internet and online games but the problem being when i want to play with friends, I cant connect to them because my NAT type is set to strict. I know how to port forward with the home hub but i cant port forward both xbox's at the same time meaning theres always one with an open NAT and one with strict NAT. Does anyone know of a way i can get both xbox's to have an open NAT type?
1 REPLY 1
Guru
Message 2 of 2
Re: port forwarding
Hi and welcome to the forum, i would use the DMZ function via port forwarding on the hub.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
