Message 1 of 2
port1 light constant flashing fbre modem
I have a Hauwei 1port modem which has developed a rapid constant flashing port1 light. This started a little while after openreach replaced the power adapter which had failed.  The Bt and openreach help pages suggest that there could be a problem with the router connection which I have checked, or the router itself. There does not appear to be noticeable loss in speed or service but it has become distraction.
1 REPLY 1
Message 2 of 2
Re: port1 light constant flashing fbre modem
Try unplugging the cable to your router, does the flashing stop 🤣
The flashing light indicates an active connection and is normal, I suspect it's not so much that it's just started - more likely you've only just noticed it
