william347
Message 1 of 2
primary email address
I no longer use my primary email address, all that comes in is spam,and the occasional message from BT regarding broadband usage allowance.
I wish to change this to the email address I have been using for some time now.
1 REPLY 1
Devon_Dave
Distinguished Guru
Message 2 of 2
Re: primary email address
You will need to contact the helpdesk on 0800 111 4567, you will need to authenticate with a few security questions, but should not be a problem.
If you get no luck there come back here and contact the mods who should be aable to help.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
