Albirt
Message 1 of 6
"Acquiring Network Address" message
Why has my PC ( wired connection) started to delay the connection to the internet and give the message "Acquiring Network Address". The PC and router have not been changed, so don't understand why I'm now getting this delay and message. The connection is made in the end.
Also my netbook ( wireless connection ) gives the message "The connection has limited or no connectivity......." and I have to go through a "Repair" process to get it to connect. Have to do this " Repair" every time I connect the netbook.
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: "Acquiring Network Address" message
Have you tried resetting your BT Home hub?
Albirt
Message 3 of 6
Restarted Home Hub 2.
Netbook connects OK now. But PC ( wired ) still has delay while its "Acquiring Network Address".
Keith_Beddoe
Message 4 of 6
Try the instructions here Static IP with Home Hub  It will then have its own address, and not have to ask the home hub.
Albirt
Message 5 of 6
Now the my wireless netbook will not connect ?
Get message "waiting for network to be ready ....." Laptop , Iphone all connect OK, only problem is netook which used to connect OK !!! Have disconnected and reconnected, retyping key, but still get same message.
Have re booted HH2, no change ??
Albirt
Message 6 of 6
Further inof, I now have assigned a Static IP Address to netbook and it connects to HH2, BUT after a few seconds it disconnects ??
