epsom56
Message 1 of 18
" connected with limited access"
just set up bt connection but cant get to home page or other webpages. am connected to home hub via a wireless dongle, and wirelsss dongle says am connected to the home hub.
however the internet icon in the system tray says " connected with limited access" and when click on browser it comes up with a message that unable to find home page/website. On my control panel it shows a yellow exclamation mark between pc and " network" (?) and a red x between network and the internet.
what is limited access - it doesnt allow ANY form of access!
am writing this @ work for obviuos reasons!
17 REPLIES 17
Message 2 of 18
Re: " connected with limited access"
Limited or local connection means that there is no path to the Internet, but the local network can be seen.
Make sure that the "Internet" light on your home hub is showing the correct state, as per instructions.
Enter http://192.168.1.254 into you web browser and see if you get the home hub menu. If you do not, then its possible that you have entered the wireless security key incorrectly, as this will also give a "limited connectivity" message.
If you can connect a direct Ethernet cable between you home hub and your computer, then try that to see if it works.
epsom56
Message 3 of 18
link to home hub didnt work so deafualted to moving the computer to within distance of the ethernet cable, which ha sgot me up and running. wirless will have to wait for another day!
james-h
Newbie
Message 4 of 18
Keith
I have a new Home Hub 3. The main PC is connected via ethernet cable and works fine, and iPad works wirelessly fine, and another PC works wirelessly fine. Laptop works fine through ethernet cable, BUT cannot achieve wireless internet connection beyond the hub itself - I get 'Limited Connection' message, and a red X between hub and internet when I run the diagnostics. Although the laptop is only a few years old, and the Home Hub claims to handle various generations of wifi (802.11.b g or n) - the laptop runs g - I am now wondering if it's a wifi compatibility problem. Is this a known issue, please, and what are the fixes?
would welcome any advice
James
Message 5 of 18
you could try changing wireless in hub to just b/g which often helps
did you install the bt cd?
Message 6 of 18
james-h
Newbie
Message 7 of 18
Thanks for the suggestion; I've now tried changing to b/g - sadly, no visible effect, so I've gone back to the recommended setting.  If I put the BT cd in again, what should I look for?
james-h
Newbie
Message 8 of 18
thanks for this - I will work through the options tomorrow. Obviously I am not alone with this issue.
Message 9 of 18
the forum suggests that you avoid the BT Cd as it can cause more problems than it can solve
Message 10 of 18
Did you try all of my options including setting the encryption to WPA only?
Make sure you are using the wireless key and not the admin password.
