Message 21 of 93
Re: reset default gateway - yet again!!
Wow first time today i actually did this without getting cut off!
speedtest results
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download  Speed
 7.93 Mbps
0 Mbps21 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 7.93 Mbps
 For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
 IP Profile for your line is - 18.33 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.94 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.94Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
Message 22 of 93
throughput still low for your profile - just keep posting as good for recording purposes while waiting for mods
Message 23 of 93
heard from mods - they gonna send me a new hub to make sure it isnt the hub thats causing the problem, which i will get on weds so as when i will get new one i will plug in and sort that then do a speedtest to see how it is then!
i might think about leavin it alone for a few days to see how it goes!
Rhian
Message 24 of 93
when you connect new hub then repost stats to compare with previous stats but also create a record just in case you need to refer back
Message 25 of 93
still awaiting the new hub to arive!
just thought i might do this again so can compare it later on!
ADSL Line Status
Connection Information
Line state:Connected
Connection time:2 days, 00:07:23
Downstream:20.26 Mbps
Upstream:1.132 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):3.5 dB / 6.3 dB
Line attenuation (Down/Up):16.7 dB / 10.3 dB
Output power (Down/Up):16.5 dBm / 12.4 dBm
FEC Events (Down/Up):7289670 / 65
CRC Events (Down/Up):248 / 2
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):3256 / 2
Error Seconds (Local/Remote):
828 / 5
Message 26 of 93
With new modem in!
ADSL Line Status
Connection time:0 days, 00:16:19
Downstream:20.58 Mbps
Upstream:1.16 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):3.0 dB / 5.5 dB
Line attenuation (Down/Up):16.9 dB / 10.3 dB
FEC Events (Down/Up):103363 / 56
CRC Events (Down/Up):15 / 17
HEC Events (Down/Up):43 / 58
Error Seconds (Local/Remote):12 / 8
Message 27 of 93
please post back hub stats in 24 hours so we can get a better idea of the errors
Message 28 of 93
ok i will post them tomorrow afternoon 🙂
Rhian
Message 29 of 93
ADSL Line Status
Connection time:1 days, 00:10:17
Upstream:1.16 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):2.9 dB / 6.0 dB
FEC Events (Down/Up):9515877 / 67
CRC Events (Down/Up):2681 / 21
HEC Events (Down/Up):7168 / 65
Error Seconds (Local/Remote):2228 / 12
Message 30 of 93
more errors with shorter connection time than you had with previous router but connection speed slightly faster and noise margin slightly lower
can you rum btspeedtester and post results to see what download speed is like
