Message 31 of 93
Re: reset default gateway - yet again!!
Message 32 of 93
download speed really low for your 20mb connection speed but still within the acceptable limits.  was test done wired?
new router has not solved the problem and if test done wired then I would contact mods and see if they can help
nothing shown as a problem for your exchange  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
if nothing
contact mods
can take up to 3 working days for mods to contact you
Message 33 of 93
i still at times get error and that i have to reset default gateway several times yesterday and once today so far!
but this has come up and no error has come up in corner for this!!
Rhian
Message 34 of 93
my tests are always set in wired connection, as far as i can see in all links you given me with exchanges - i cant find anything about my local area.
i think i will ask again for mods help 🙂
thanks!
Rhian
Message 35 of 93
you have tried eveything within your scope including a new router and still download speed very low for your conenction speed
Message 36 of 93
Please keep us posted on your progress
Message 37 of 93
just copied part of my message from mod so you can understand whats going on :-
The tests I have ran on your line do show that when your SNR is at 3DB there does seem to be an increase in errors on the line. So what I have done today is I have set your line to 6DB to see if this reduces the number of error. The change to the SNR should take affect in the next 24 hours, please keep an eye on your connection over the next few days and let me know if you see an improvement.
at the minute the internet have been kinda laggy and slow on loading pages and when i doing updates on itunes (which failed 3 times!) and facebook i have had to reset default gateway 3 times already since i been on pc at 6.30pm. i will wait until tomorrow afternoon to see if there is any improvement with this, then will leave it until friday to see how it goes before contacting mods again.
Rhian
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 06:23:26
Downstream:20.46 Mbps
Upstream:1.176 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):2.9 dB / 6.1 dB
Line attenuation (Down/Up):16.8 dB / 10.4 dB
Output power (Down/Up):16.4 dBm / 12.4 dBm
FEC Events (Down/Up):126722 / 39
CRC Events (Down/Up):121 / 7
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):689 / 12
Error Seconds (Local/Remote):323 / 3
Message 38 of 93
the higher noise margin which was the standard not long ago of 6db will hopefully help your throughput.  just need to wait as mod said but please post stats after change to 6db
Message 39 of 93
ok its been just over 24 hours and i had to reset default gateway twice since i been on computer just before 6pm.
ADSL Line Status
Connection time:1 days, 04:22:35
Upstream:1.176 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):3.1 dB / 6.1 dB
FEC Events (Down/Up):272103 / 39
CRC Events (Down/Up):257 / 9
HEC Events (Down/Up):2118 / 13
Error Seconds (Local/Remote):430 / 3
Message 40 of 93
you need to go back to the mods as the reset to 6db does not seem to have worked
