Message 41 of 93
Re: reset default gateway - yet again!!
thanks i have now written back to the mods about this!
wish this can get sorted as i want things that i can watch videos in full and download updates without getting cutoff again 🙂
Rhian
Message 42 of 93
i had to reset the dafault gateway twice already this afternoon
ADSL Line Status
Connection Information
Line state:Connected
Connection time:2 days, 02:28:54
Downstream:20.46 Mbps
Upstream:1.176 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):3.0 dB / 6.1 dB
Line attenuation (Down/Up):16.8 dB / 10.4 dB
Output power (Down/Up):16.4 dBm / 12.4 dBm
FEC Events (Down/Up):384786 / 55
CRC Events (Down/Up):363 / 11
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):4876 / 16
Error Seconds (Local/Remote):504 / 3
Message 43 of 93
your router stats are ok and it has been connected for over 2 days  could the problems be with your network card - are the drivers up to date from manufacturer's website not windows update
Message 44 of 93
windows even looked online via device manager and says it is up to date  - via rhine ii fast ethernet adapter but cant find product code or number to see if i can find one online!
Message 45 of 93
Message 46 of 93
my brother is going to help me in regards to this at the weekend - i might be needing a new one if i cant find the new up to date driver for the card, but in any regards i will see what else mods will say about this as well 🙂
Message 47 of 93
Sorry if this has been covered but a quick skim through the thread it seems to be concentrating on the connection between hub and internet when the problem you have is between PC and hub.
Have you tried a different network cable and a different port on the hub?
Message 48 of 93
yea i have tried swapping ports on hub and still have same thing, i only have one wire connected to computer, we will check the network card cos i have had this problem before in my old home and it was before i had the hub. i will also bring another wire back from my brother to check it out.
Rhian
Message 49 of 93
Hi post back when you are ready
Message 50 of 93
Seems like it reset itself at 5am on thurs morning, still get resets of default gateways last night,
ADSL Line Status
Connection time:0 days, 17:55:10
Downstream:20.66 Mbps
Upstream:1.168 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):3.1 dB / 6.1 dB
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):3763 / 0
HEC Events (Down/Up):4935 / 0
Error Seconds (Local/Remote):4048 / 19
