Message 51 of 93
Re: reset default gateway - yet again!!
just noticed now from other ones i have no FEC Events this time around! means something i dont know but i am a bit more stable now watching youtube video today! This is just now after i just played a video on youtube!
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 18:06:46
Downstream: 20.66 Mbps
Upstream: 1.168 Mbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.5 Annex A
Latency type: Fast
Noise margin (Down/Up): 3.0 dB / 1.8 dB
Line attenuation (Down/Up): 16.8 dB / 10.4 dB
Output power (Down/Up): 16.4 dBm / 12.4 dBm
FEC Events (Down/Up): 0 / 0
CRC Events (Down/Up): 3797 / 0
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
HEC Events (Down/Up): 4998 / 0
Error Seconds (Local/Remote): 4081 / 19
Message 52 of 93
your connection is now on 'fast' instead of 'interleaved' hence the reason for no more fec errors but you may find that the crc/hec errors and errors seconds increase faster than they did before due to interleaving being turned off.
just keep checking your stats but no manual router resets
Message 53 of 93
so i thinking they changed it on the line? i didnt even manually reset it at 5am i was asleep at that point! lol i will keep an eye on this over the weekend and next week!
Message 54 of 93
any problems then just come back and repost new stats
Message 55 of 93
ok i am wondering what are they doing with my bb?
ADSL Line Status
Line state:Connected
Connection time:0 days, 01:14:45
Downstream:20.35 Mbps
Upstream:1.208 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):3.4 dB / 6.0 dB
Line attenuation (Down/Up):16.9 dB / 10.3 dB
Output power (Down/Up):16.5 dBm / 12.4 dBm
FEC Events (Down/Up):176955 / 0
CRC Events (Down/Up):5 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):5 / 0
Error Seconds (Local/Remote):68139 / 22
Message 56 of 93
you have had interleaving turned on to stabilise your connection this is automatic when the errors climb to high
Message 57 of 93
stats still look fine with good 20mb speed.  error seconds are high but they have not reset when connection reset so misleading
Message 58 of 93
thats whats making me confused as at the moment it is stable on this at the min, thought i be left on fast but i dont think so, i not even manually resetting it so something is reseting it!
Message 59 of 93
plus i havent heard anything from mods although i did contact them last week! :S
Message 60 of 93
As john46 said the automatic system has changed you to interleaved due to the number of errors accumulating to make sure your line stays stable Still looks ok with 20mb connection
