Message 61 of 93
Re: reset default gateway - yet again!!
 can play youtube videos but it buffers and loads while playing video not in a clear way like it did before on fast speed! but apart from that it seems stable with no default gateway resets on this!
Message 62 of 93
interleaving will provide a more stable connection and more stable throughput particularly during evenings when the noise margin reduces and line errors start to increase
Message 63 of 93
 the hub just reset itself!
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:03:33
Downstream:20.4 Mbps
Upstream:1.149 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):3.2 dB / 6.1 dB
Line attenuation (Down/Up):16.7 dB / 10.4 dB
Output power (Down/Up):16.5 dBm / 12.4 dBm
FEC Events (Down/Up):950 / 0
CRC Events (Down/Up):0 / 9
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 6
Error Seconds (Local/Remote):68212 / 24
Message 64 of 93
stats after reset have come back very similar to before but resets are annoying.  if there was a problem then your noise margin would increase with a drop in your conenction speed
Message 65 of 93
i dont know what i can do but it seems it keeps reseting itself rather than me reseting default gateway on computer. i dont know whether i should contact mods again? As i contacted them last time last week yet i havent had any nofication or reply off them! hmm i wonder if i could see if the line itself is noisy? i will flick thru the thread and see if i can do it 🙂
Rhian
Message 66 of 93
is quiet line test ok?
Message 67 of 93
quiet line is surprising quiet! i have done speed test as well n all seems normal
Message 68 of 93
speedtest looks good
Message 69 of 93
Just had alook again and noticed that noise margin have gone up!
ADSL Line Status
Connection time:0 days, 00:26:07
Upstream:1.149 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):3.2 dB / 6.2 dB
FEC Events (Down/Up):7131 / 0
CRC Events (Down/Up):1 / 9
HEC Events (Down/Up):4 / 6
Error Seconds (Local/Remote):68213 / 24
Message 70 of 93
just leave the line to train now as it has had a lot of problems and the MSAN needs training history to provide a stable connection
