Message 71 of 93
Re: reset default gateway - yet again!!
i have been leaving the hub on anyway - as i normally do, just find it weird reseting itself without no warning!
if i have any more problems i will come back but hopefully things now settle! (well fingerscrossed!)
Rhian
Message 72 of 93
the line is trying to retain so an odd disconnection is normal
Message 73 of 93
that change in noise margin is minimal and nothing to be concerned about - jump to 6db then post back
Message 74 of 93
Just had this number ring me 08000285085, on my mobile. I know its off bt but is there an number I can ring back as I on mobile and can't ring free numbers
Message 75 of 93
it was the forum mods trying to contact you i would expect they should call you again
Message 76 of 93
Ok I will await them to ring me back. Hopefully this afternoon/evening
Message 77 of 93
Had a email from the mods, and things seems set to what they said it should be on.
Ah well just gonna wait and see if things calm down now.
Rhian
Message 78 of 93
then I would just leave connection on 24/7 and it should settle down.  obviously if noise margin starts to climb then come back and post new stats
Message 79 of 93
time: 9.19pm - peak time i suppose!
things are still stable download and youtube/game wise! 🙂
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 09:35:49
Downstream:20.4 Mbps
Upstream:1.149 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):2.7 dB / 6.0 dB
Line attenuation (Down/Up):16.7 dB / 10.4 dB
Output power (Down/Up):16.5 dBm / 12.4 dBm
FEC Events (Down/Up):181398 / 0
CRC Events (Down/Up):46 / 37
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):506 / 68
Error Seconds (Local/Remote):68248 / 36
Message 80 of 93
Still looking ok. Annoying the error seconds didn't reset to zero last time as it gives false impression
