zabakkiller
Message 1 of 21
reset my noise margin
can you reset my noise margin back to o9db or 6 db as i have now 12db hence my speed down thanks
20 REPLIES 20
imjolly
Message 2 of 21
Re: reset my noise margin
welcome to the forum
your noise margin is higher than normal due either your router dropping connection or manual resets or a combination of both.  before the mods wll help with your noise margin you need to post the adsl stats from your router
zabakkiller
Message 3 of 21
hi as i try iplate is been lot of restart from my side but know i wont back my noise margin as iplate give my 1 mb lower speed i take off and get my conection back near to normal just noise is to high
 stat from ruter is
con.with no drope 1day and 7hour
noise 11.5 down and 5.9 up
line 55 down  and 34.5 up
output powr 0down and 12.7 up
ccr error 251/2
sync speed 3195 down  781up
i cant copy my stat as i write from tablet
imjolly
Message 4 of 21
you need to post your stats again when you can show 3+ days stable conenction before mods will help with your noise margin
john46
Message 5 of 21
once you can show 3days + stable connection with no hub restarts then we can get you in touch with the forum mods for a noise margin reset but you must be able to show 3days stable first
zabakkiller
Message 6 of 21
ok I will by post after 3+ stable day
thanks for now
zabakkiller
Message 7 of 21
hi I am back for reaguest my noise margin reset as i have now staboe connoction more that 3 day can someone reset to 9db or 6db from my 12db thanks so much as my speed is now slowest that normal with tish high noise margin
my router stat is
conectoin 3 day and 9:16:18
sync down 3049 up 349
 noise 12 db down and 15 db up
atten. 55db down and 34 up
 output power 0 db down 12.7 up
ccr error 2445/120
thanks and sorry about my post like this but i got only tablet and phone now
imjolly
Message 8 of 21
the mods will help when they see your post  the contact us is here  when mods post  contact mods link.jpg
PaddyB
Moderator
Moderator
Message 9 of 21
Hi Zabakkiller,
I'll be able to take a look at your connection. Please could you send me in your details using the "Contact Us" link found in my profile?
PaddyB
zabakkiller
Message 10 of 21
hi PaddyB thanks
i send form
and let my now after you all done thanks again
