jimbo59
Message 1 of 4
s
seem to be running slowSmiley Mad
tryed to view a 4 min vid from utube which took about 40 mins save going on heres the stats
Download speedachieved during the test was - 133 Kbps
 For your connection, the acceptable range of speeds is 50-250 Kbps.
 IP Profile for your line is - 135 Kbps
ADSL line status
Connection information
Line state Connected
Connection time 0 days, 10:55:31
Downstream 192 Kbps
Upstream 224 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.1
Latency type Interleaved
Noise margin (Down/Up) 5.9 dB / 6.0 dB
Line attenuation (Down/Up) 47.0 dB / 26.0 dB
Output power (Down/Up) 12.2 dBm / 11.9 dBm
Loss of Framing (Local) 12
Loss of Signal (Local) 2
Loss of Power (Local) 0
FEC Errors (Down/Up) 692 / 2
CRC Errors (Down/Up) 46 / 2147480000
HEC Errors (Down/Up) nil / 2
Error Seconds (Local) 55
tell me what you think load of gobblygook to me
3 REPLIES 3
Message 2 of 4
Re: s
your connection seemed to improve after the engineer visit a few weeks ago but your stats now look worse than original.  Has anything changed? moved?
jimbo59
Message 3 of 4
Re: s
No nothing added or removed as was when he visited as you said I did get up 750kbps  but now gone down and hubs been left on 24/7 since
Message 4 of 4
Re: s
if nothing has changed since engineer visit and you have been connected 24/7 - but there have been resets by the router as connection time only 10hrs.  I would email the mods for assistance give your account and phone number and a link back to this thread forum.moderation.team@bt.com
