Message 1 of 3
safe to rename router pre activation
heat, Router has arrived activation date is monday. is it safe to rename the router and change the password before then so I can start connecting devices to it before disconnecting old router
2 REPLIES 2
Message 2 of 3
Re: safe to rename router pre activation
Message 3 of 3
yes
when I get a new hub I always just plug it in before internet connected and change SSID and password to that of previous hub so my devices connect as soon as I start to use the new hub
