Message 1 of 4
samsung 335
i am getting a samsung chat 335,does anyone know if it is easy to connect to bt fon or openzone with this phone or will i have problems????. btw it has wi fi
3 REPLIES 3
Message 2 of 4
Re: samsung 335
if you have wifi then should be able to connect without much of a problem.  as I don't think there is an app for your chat 335  you will need to find a BTFON signal then lgoin is by using the primary btinternet email address and password - sub accounts will not work
Message 3 of 4
Re: samsung 335
Further to what imj has said, I see it has a "Proprietary operating system," connecting to wi fi / BTOZ will have to be done manually as the Fon app wont work I think.
But thats no problem, you're still good to go Smiley Wink
AQ.
"Welcome to Royston Vasey - You'll never leave."
Message 4 of 4
Re: samsung 335
thank you both for your help
