some of my emails take ages to leave me and don't get saved; others leave immediately and do get saved. what am i doing wrong?
Are you using an e-mail client or webmail?
Hi. I am using an e-mail client, with Apple Mail. The problem started when i switched to bt.
Is that using IMAP?
yes.
You need to create a local folder on your e-mail client, then alter the client so that it keeps a copy of the sent e-mail in that location, and not on the normal sent folder.
This was discussed on another thread, when i can find it.
Here is one of the threads.
but I think there was also one relating to the MAC.
thanks for that. unfortunately i have no idea how to do this; so any pointers would be gratefully received! (i don't underestand why bt don't organise this properly)
