Message 1 of 3
setup ipv6 with BT Infinity(VDSL) through Mikrotik RB750 GR3
Hello
I met a very strange problem about ipv6,I got a Mikrotik RB750 GR3 (ROS 7.2 RC1)router and Huawei HG612 modem, ipv4 part is no problrm. But when I try to setup v6 part,some oddly situation arrived.
I add a dhcp-client with 56 prefix
and status seems ok
and I add address
everything seems ok, and computer and cell phone shows IP v6 address assigned. the fromat is start with 2a00:23c7:f684
BUT
when i go to test-ipv6.com  and ipv6-test.com,include computer and cell phone, got this kind of result
and also, at win10 ethernet status shows ipv6 "no internet asscess"
When i restart router or modem, the assigned V6 IP of terminal changed synchronous,"pretend" they are really working, but they are not working at all.
As firewall part, I just turn off the firewall, to avoid any interference。
And i reset router, repeat again, no change.
Changed to BT homehub6A, every problem disappear.
So, could any one give me some suggestion to solve this uncommon miracle?
Thank you very much.
2 REPLIES 2
Message 2 of 3
Re: setup ipv6 with BT Infinity(VDSL) through Mikrotik RB750 GR3
Finally, it solved, after ROS 7.2RC5 updated.
And do not select Add default route in DHCP v6 client
Message 3 of 3
After ROS updated.
The related fix log of ROS 7.2RC5 about this ipv6 issue:
ipv6 - do not add duplicate dynamic prefix when static already exists;
