I seem to be having issues access the sipgate VOIP service while using mobile data.
Running an iOS device, I can connect using the GS Wave app over WiFi however as soon as I disconnect from WiFi and move over to mobile data, I can no longer connect.
I've tried on my work phone (Vodafone) and it connects without issue.
Any ideas?
@walderstonwrote:I seem to be having issues access the sipgate VOIP service while using mobile data.
Any ideas?
The obvious iOS check would be SETTINGS/MOBILE DATA and scroll down to see whether sipgate VOIP has mobile data turned on.
If already turned on, then a quick check of your MyBT to ensure you have sufficient data allowance remaining for the current month.
Yep to both. - Note it is not sipgate VOIP but GS Wave that needs the data access (which it has).
Oooops!
How about this video (a little old now)
https://www.youtube.com/watch?v=2-69C5NsAiw
I've already followed that guide along with the guide on sipgate's website - https://basichelp.sipgate.co.uk/hc/en-gb/articles/204236351-Grandstream-Wave-Android-Apple-iOS- (leaving everything default and then custom ports).
When on WiFi, the app connects to sipgate however when on BT Mobile data, it fails - no error messages etc, just the device could not register.
